除木馬
除木馬
文章super » 2008年 8月 15日, 21:51
代碼: 選擇全部
REM �]定說明檔位置
SET PROFILE_V="%USERPROFILE%\桌面\病毒警告.txt"
For %%a In (
"C:\WINDOWS\rundl132.exe"
"C:\WINDOWS\Config\svhost32.exe"
"C:\WINDOWS\$hf_mig$\svhost32.exe"
"C:\WINDOWS\help\rundll32.exe"
"C:\windows\system32\ct1dll.dll"
"C:\WINDOWS\system32\viwpt.DLL"
"C:\WINDOWS\system32\PDLL.DLL"
"C:\WINDOWS\system32\rundl132.exe"
"C:\WINDOWS\system32\dlyy.DLL"
"C:\Program Files\rundll32.exe"
"C:\Program Files\Microsoft\svhost32.exe"
"C:\Program Files\Windows Media Player\svhost.exe"
"C:\Documents and Settings\User\桌面\複製 -新增文字.bat"
) Do (
if exist "%%~a_" del "%%~a_"
if exist "%%~a" (
   ren "%%~a" "%%~nxa_"
   echo 發�{疑識病毒檔案[%%~a]改名為[%%~nxa_]                >> %PROFILE_V%
   set VS_O=YES
   SET WinFILE=%windir%\WIN.ini
   SET WinSYS=%windir%\SYSTEM.ini
if [%VS_O%]==[YES] (
   reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run" /v "load" /f
   reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run" /v "qm" /f
   reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run" /v "fzg" /f
   reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run" /v "nwiz" /f
   reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon" /v "Userinit" /f
   REG ADD    "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon" /v "Userinit" /t  REG_SZ /d "C:\WINDOWS\system32\userinit.exe," /f
   echo 刪除以下機碼:                        >> %PROFILE_V%
   echo "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"  "load"   >> %PROFILE_V%
   echo "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"  "qm"   >> %PROFILE_V%
   echo "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"  "fzg"   >> %PROFILE_V%
   echo "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"  "nwiz"   >> %PROFILE_V%
   echo 閱讀本檔案後請刪除,下次�}機如再次出�{本文件代表您又中毒了!!       >> %PROFILE_V%
   echo %TATE% %TIME% By EverSuper 長偉資訊               >> %PROFILE_V%
   echo ; for 16-bit app support   > %WinFILE%
   echo [fonts]         >> %WinFILE%
   echo [extensions]      >> %WinFILE%
   echo [mci extensions]      >> %WinFILE%
   echo [files]         >> %WinFILE%
   echo [Mail]         >> %WinFILE%
   echo MAPI=1         >> %WinFILE%
   echo CMCDLLNAME32=mapi32.dll   >> %WinFILE%
   echo CMCDLLNAME=mapi.dll   >> %WinFILE%
   echo CMC=1         >> %WinFILE%
   echo MAPIX=1         >> %WinFILE%
   echo MAPIXVER=1.0.0.1      >> %WinFILE%
   echo OLEMessaging=1      >> %WinFILE%
   echo [MCI Extensions.BAK]   >> %WinFILE%
   echo aif=MPEGVideo      >> %WinFILE%
   echo aifc=MPEGVideo      >> %WinFILE%
   echo aiff=MPEGVideo      >> %WinFILE%
   echo asf=MPEGVideo      >> %WinFILE%
   echo asx=MPEGVideo      >> %WinFILE%
   echo au=MPEGVideo      >> %WinFILE%
   echo m1v=MPEGVideo      >> %WinFILE%
   echo m3u=MPEGVideo      >> %WinFILE%
   echo mp2=MPEGVideo      >> %WinFILE%
   echo mp2v=MPEGVideo      >> %WinFILE%
   echo mp3=MPEGVideo      >> %WinFILE%
   echo mpa=MPEGVideo      >> %WinFILE%
   echo mpe=MPEGVideo      >> %WinFILE%
   echo mpeg=MPEGVideo      >> %WinFILE%
   echo mpg=MPEGVideo      >> %WinFILE%
   echo mpv2=MPEGVideo      >> %WinFILE%
   echo snd=MPEGVideo      >> %WinFILE%
   echo wax=MPEGVideo      >> %WinFILE%
   echo wm=MPEGVideo      >> %WinFILE%
   echo wma=MPEGVideo      >> %WinFILE%
   echo wmv=MPEGVideo      >> %WinFILE%
   echo wmx=MPEGVideo      >> %WinFILE%
   echo wpl=MPEGVideo      >> %WinFILE%
   echo wvx=MPEGVideo      >> %WinFILE%
   echo ; for 16-bit app support   > %WinSYS%
   echo [drivers]         >> %WinSYS%
   echo wave=mmdrv.dll      >> %WinSYS%
   echo timer=timer.drv      >> %WinSYS%
   echo [mci]         >> %WinSYS%
   echo [driver32]         >> %WinSYS%
   echo [386enh]         >> %WinSYS%
   echo woafont=app950.FON      >> %WinSYS%
   echo EGA80WOA.FON=EGA80WOA.FON   >> %WinSYS%
   echo EGA40WOA.FON=EGA40WOA.FON   >> %WinSYS%
   echo CGA80WOA.FON=CGA80WOA.FON   >> %WinSYS%
   echo CGA40WOA.FON=CGA40WOA.FON   >> %WinSYS%
REM �]定記錄主機位置
if NOT [%SERVER%] == [] type  %PROFILE_V% >> "%SERVER%\Vtemp\%COMPUTERNAME%.txt"
回到 Windows 筆記
